Not really plans. I opened the power supply, knew the current limitations of the supply and figured how many AT machines it would run.
For you, you would probably want to get some form of 100 watt power supply (ATX) and see if you can power the boards with that. If it looks fine for your needs, then follow the following.
Get a 300 Watt ATX power supply. You going to need to do some shopping, but for now, we just want to look at the PCB (PC Board) in the power supply. Look at the wires going in. Now I'm a little rusty with my ATX pin out off the top of my head so these could be wrong, but I believe they are correct.
Note, I know this is right, I double checked
This would be the side with out the locking tab
Pin Signal
1 3.3vdc
2 3.3vdc
3 Ground
4 5vdc
5 Ground
6 5vdc
7 Ground
8 Power Good (5v if good)
9 5v sb(This wire might not go to the standard 5vdc plane
10 12vdc
Other side starting back near pine 1 (orange wires)
11 3.3vdc
12 -12vdc
13 Ground
14 On/Off Control (short this with ground to power on ATX power supplies when no MoBo is connected. Very handy to see what blew up when a machine died
15 Ground
16 Ground
17 Ground
18 -5vdc
19 5vdc
20 5vdc
OK, now here is the fun part. You can see that you have alot of the same wires going to different pins. Now if you have 3 power supplies that's 60 wires. There is no way in heck you will be able to put 60 wires into that PCB. So, you are going to have to do some soldering.
Get some solid copper wire, of the same diameter as the hole on the PCB board. Not sure what gauge off the top of my head, but this is pretty heavy stuff. Now, MAKE SURE if this copper has insulation on it to scrape it off. (A thin film of plastic that you can't see, but it will scrape off with a knife). Take about a 1 inch part and take off all of the insulation. Then bend one end into a P so that the loop part is big enought for you to put plenty of wires through it.
This is where it gets fun. You going to need some parts. If you go to this link for
Jameco you will see that they have ATX connector parts. You need the pins (147395) and the connector (147387) to do this. You might want to get the crimper (99442), but it is not needed. I would actually buy the parts, and do it with a pair of pliers. If you feel you need the crimper, buy one locally so you can return it if you decide it's not much better.
Now that you have the parts, you will need wire. Try to find some of the same gauge as the existing power supply wires. (20 gauge???)
Ok, now you figure out the lengths of wire you need. Add 5 inches, and start cutting the 60 lengths. Then strip about 1/2 inch of insulation off of one end, and about 3/4 inch off of the other end on each wire. Crimp/plier on the pins to the 1/2 inch end, and then tin it with solder for a solid electrical connection. Then whey you have 3 set's of these done, take the wires, and match up all the common styles. 5 volts with 5volts, grounds with grounds, and special signal wires with themselves. (You will always get about 3 bundles of 3 wires, don't try matching power good with the 5 volt line to save time, it won't work).
Anyway, once you have them matched up, take the solid copper P figure, and start adding wires to it. To do this, just make a V at the end of the wire, hook it onto the copper P, then mash the wire closed around the V, and solder. (You can either solder them on one at a time, or all at once. I did the all at once, and found it to be easier) Having another set of hands comes in handy here.
Once you have a group of wires hooked into the P, go to the nice power supply you have, and start removing all of the leads that go to internal computer connections. (FDD and HDD power lines also, maybe leave one or two on if you need, but you might be putting your power supply at risk). Once the wires are pulled out, you will see the board is labeled with their locations. If not, well, maybe we should have written them down first.
🙂 (I figure your going to read this all the way through at least once). Take the P figure you have and stick the | into the power supply hole. Try to arrange it so that the P won't be too near other P connectiors. (Now if you have either black electrical tape, or heat shrink, cut a bit off and put it onto the P/wires. Put the end into the board, and put it down pretty close to the board. Solder in the connection with a clean amount of solder. then get the heat gun and shrink your heat shrink, or get your tape out and cover the P and all the exposed wires cleanly.
Repeat until done.
Now pull out your multi meter and power on the power supplies. (Neat Note. Now that you have modded 3 connections into one power supply, only one power switch needs to be connected to a machine to power it on. This means that you can only short one of the power on/off wires to ground to turn on this supply). If any smoke comes out go back to start and look at your wires. If everything looks ok, start testing the voltages out. Again power good should be around 5 volts. You can assume that if it's with in 1 volt of the 12 and 5 volt lines your fine, and about 1/2 a volt for the 3.3 vdc lines. Check all the pins, then check again, then get someone else to check the last time. This is because if your wrong here you could end up loosing some good hardware. Now for the faith part. You might want to get some POS board, and hook them up to the supply. Once this is done, power it on and see if all 3 boards post and turn on correctly. If one doesn't turn on or they all don't turn on, double check the pins again on the multi meter. If two turn on, and one doesn't, try disconnecting the one that didn't power on and see if the others power on ok. Or, try disconnecting the one that powered on, and see if the no post powers on ok.
The reason for all of this, is to make sure, the power supply really has enough juice to power the boards. You could be brown outing, or you could have one wire off. (trust me, it's a pain in the butt to fix if you do have one wire off.)
Repeat until done with desire to mod power supplies.
It takes time, and isn't always easy, and you should keep at least one power supply handy incase one fails. If it fails, it's just a mater of pulling out all the P's in the bad one, and connecting them up to a new board.
Man, this is a long post.
Any Questions?
LD
