Are you facing any problem with starting Facebook Messenger in your device after updating to iOS 12? Many users complained that after upgrading their devices to Apple’s latest iOS 12, Facebook Messenger is either not delivering messages or crashing completely. If you are stuck with the same issue, then try to restart your phone or reinstall the app. If the problem prevails in spite of that, then given below are few more solutions. Here’s how you can resolve any issue with Facebook Messenger in iOS 12.
Method 1: Update the App
Step 1
Click ‘App Store’
It’s highly possible that you have not updated the ‘Facebook Messenger’ app. To update the app, go to the menu, and click on ‘App Store’. It will show you a list of all the downloaded apps in your phone.
Step 2
Click ‘Update’
If your app is not updated, then there will be a blue tab beside the app with ‘Update’ written on it. As click that tab, your ‘Facebook Messenger’ gets updated.
Method 2: Reset Network Settings
Step 1
Click ‘Settings’
You are likely to face a lot of network issues with ‘Facebook Messenger’, so it’s a good idea to reset the network. Click ‘Settings’ from the Menu. It will open up all the commands to customize the device’s settings.
Step 2
Click ‘General’
Select ‘General’ from the options to displayed on the screen. You can access to all the 'General Settings' for date and time, or keyboard, etc.
Step 3
Click ‘Reset’
select ‘Reset’ from the list of commands on the screen that will give you options for resetting certain applications.
Step 4
Click ‘Reset Network Settings’
Click on ‘Reset Network Settings’, enter the 'Passcode' of your device, and confirm 'Resetting Network Settings'.
These were some of the ways to fix Facebook Messenger in your iOS 12.
