How to remove tint from car window?
LuckyTaxi
To make the long story short, some young cop pulled me over and gave me a warning for having tint that's too dark. He's a moron cuz he said you cant have tint in Pennsylvania. He's a moron and he was just out to get me from the beginning. Anyways, I have ten days to remove it and then I need to show up with the car at the local police district to have them inspect it.
Whats the easiest method of removing the tint from my two back windows along with the rear?
They make some spray stuff that you can use. In my last car, the tint had bubbled after about 10 years so I thought it would be a nightmare to get the stuff off. As it turned out, I bought a bottle of that spray at Walmart and used a razor blade scraper and it came off pretty easy. The spray kinda dissolves it. When I was done, you couldn't tell it ever had tint on it.
Good luck.
I'd call up a place that does car tinting and tell them you have a concern that your car might be tinted too dark adn ask if they can take a look at it for free (don't tell them about the ticket). Chances are that there is a limit to the amount of tint you can have and the shop might haev a way of testing that. THe cop is just eyeballing it and if you can get the shop to prove that you are within the legal limits, then you can take it to the cops and thank them for wasting your time....
PA Motor Vehicle Code
Ch. 45 75 Section 4524 (e)(1)
(e) Sun screening and other materials prohibited.
(1) No person shall drive any motor vehicle with any sun screening device or other material which does not permit a person to see or view the inside of the vehicle through the windshield, side wing or side window of the vehicle.
(2) This subsection does not apply to:
(i) A vehicle which is equipped with tinted windows of the type and specification that were installed by the manufacturer of the vehicle or to any hearse, ambulance, government vehicle or any other vehicle for which a currently valid certificate of exemption has been issued in accordance with regulations adopted by the department.
(ii) A vehicle which is equipped with tinted windows, sun screening devices or other materials which comply with all applicable Federal regulations and for which a currently valid certificate of exemption for medical reasons has been issued in accordance with regulations adopted by the department.
(3) A certificate of exemption shall be issued by the department for a vehicle which is:
(i) Registered in this Commonwealth on the effective date of this subsection and is equipped with a sun screening device or other material prohibited under paragraph (I) on the effective date.
(ii) Equipped with tinted windows, sun screening devices or other materials for a physical condition that makes it necessary to equip the motor vehicle with sun screening material which would be of a light transmittance or luminous reflectance in violation of this section.
(A) A certificate of exemption for medical reasons shall be issued only if the owner or registrant of the vehicle, or a person residing in the household of the owner or registrant who regularly drives or is driven in the vehicle, suffers from a physical condition deter-mined by the department, in consultation with the Medical Advisory Board, to justify the exemption.
(B) Any person requesting an exemption for medical reasons shall have his physical condition certified to the department by a licensed physician or optometrist.
(4) A certificate of exemption issued under this subsection shall be carried in the vehicle and displayed on request of a police officer.
(5) Upon the sale or transfer of the vehicle to any person who does not qualify under paragraph (2)(ii), the exemption shall be null and void. Prior to the sale or transfer of an exempt vehicle, it shall be the sole responsibility of !he owner or seller of a formerly exempt vehicle to remove all sun screening or other materials from the vehicle. At the time of the sale or transfer of a formerly exempt vehicle, the owner shall remove and destroy the certificate of exemption for physical reasons and provide the purchaser with a notarized statement setting forth the name and address of the owner or seller, the vehicle identification number, year and model, and the business entity and process used to remove the sun screening or other material.
PA STATE INSPECTION PROCEDURES Section 175.80
(2) Check glazing.
(i) Check glazing and REJECT IF any of the following apply:
(A) Approved safety glazing is not used in every windshield, window or wing.
(B) Any sign, poster or other non-transparent material obstructs, obscures or impairs driver's clear view of highway or any intersecting highway. See Appendix C.
(C) Non-transparent material extends more than 3 inches from lowest exposed portion of rear window, rear side windows or rear wings. See Appendix C.
(D) Motor vehicle has any sign, poster or other non-transparent material on windshield or front side windows, other than officially approved and properly located parking stickers.
(E) Glass is shattered or broken or has any exposed sharp edges.
(F) Windshield is removed.
(G) There are any defects in acute area of windshield,-center of critical area on driver's side of vehicle directly in driver's normal line of vision, 8 _ inches wide and 5 1/2 inches high-or discolorations or hazardous cracks to front, right, left, or rear of driver which would interfere with driver's vision. See Appendix C.
(H) Class etchings, except those used for identification, are on windshield or front side windows.
(I) Glass etchings extend more than 3 inches
What kind of tint do you have? If it's 5%, good luck..but if it's 20-35%, you could probably get away with it (according to the links, anyway).
the new cars on the lots have tinted windows so it must be okay...I guess its just the amount of tint thats illegal
In some states, I think it matters if it was from the dealer or aftermarket...same thing with HIDs -- factory is legal, aftermarket apparently isn't.
I just drive with my windows down all the time....
I'd get tint.... but my windows are always down, making it pointless....
but if I had tint, I'd never get in trouble, because my windows are always down.....
:thumbsup:
btw, what kind of PA cop pulled you over?
If your car has passed inspection since the tinting was done, then you're in the clear, as that's one of the things they check on.
More info for you, compliments of Google and my curiosity.
A 25-30% tint hardly looks any darker, and a deep tint (even approaching 50%) still allows the backseat to be seen pretty clearly through the window, so I'm under the impression that you're pushing 60-70% if the cop even thought to mention it. Seeing as you had to emphasize that "he's a moron" twice, at the beginning of two consecutive sentences, the case is furthered that you are the true moron here. Get them down to at most 40% and you're unlikely to have further problems.
You're dumb. The lower the percent, the darker the tint.
That is all.
That is all.
Depends on if you're talking about tint or transmittence.
And DIAF.
The tint percentage is the amount of light allowed to pass through. A 20% tint is dark..a 50% tint is light. I've never seen lighter than 50%..
I have 20% on my car -- I've been pulled over and it wasn't mentioned..
Most states will allow tints to all windows except the front two windows, and the windshield. Any new car with tints will have them on the rear seat windows and back windshield.
In California it's illegal to have any sort of tint at all to the front three windows..
That is all.
And DIAF.
No, it's the same damn thing.
"Tint darkness is measured by the percentage of light that is allowed throught the tint. Therefore, lower percent tints are darker (example: 5% tint only allows 5% of all light rays to pass through)."
You go DIAF.
All right the guy is the moron because he contradicted himself twice. He was pretty nice so I didnt want to make a scene. Two other cops backed him up and I thought that was a little too harsh. Anyways, he stated my tint is 14%. I'm going to check and see if 14 really exist. I'll try to get it down to 20%. Look, I'm not blaming the guy for stopping me because of my tint, but his motivate was something else. My car has 18 inch rims along with the tint and I look like a thug coming from work! it's not my fault I wear my hat backward and no I wasnt speeding! I work in a very wealthy community in Radnor, PA and I have never been stopped before with this car.
luckily, the cops never say anything to me about my tint...and its 10% i think...pretty dark...i like it...from what i've heard they will give you sh!t about mirror tint for some reason though...
