How to remove leftover glue after removing emblems from car?
Eli
Super Moderator | Elite Member
8
My brother took off some of his emblems and wants to remove the sticky left behind.
He used a whole small bottle of goo-gone, but it was rather ineffective.
Suggestions? Obviously, paint damage is to be avoided.
vi edit
62,484
8,345
Hair dryer to heat it up and a clay bar to get it off.
TheLonelyPhoenix
5,594
Originally posted by: Eli
Originally posted by: sohcrates
you need a heat gun and or hair dryer and some patience
Elaborate?
Heat will melt off the adhesive, it will wash off easily afterwards. Shouldn't cause any damage to the clearcoat or paint, although you can kiss goodbye your wax job in that area.
Never removed an emblem myself, but the hair dryer seems to be the method of choice.
TechnoKid
5,575
Originally posted by: Zim Hosein
Originally posted by: radioouman
peanut butter
:Q
the oil in the PB help to release the adhesive.
a good way of taking it off is to use a rubber eraser, you can use the tan/light brown ones, or the pink ones will do. The vinyl ones from staedtler might work too. Don't scrape it off.
Next time in the furutre a heat gun plus dental floss is the way to go. Then just use 3M adhesive & wax remover, or the eraser trick.
Zim Hosein
65,317
403
I didn't know about PB TechnoKid & TuxDave, thanks :beer: :beer:
