My athlon 1ghz processor has way too much thermal compound goop all over the place. I cleaned off the die really well with alchohol and a q tip, and scooped away as much compound off the area surrounding the die. is that good enough? Should I try to really clean off the rest of the CPU, or is cleaning the die good enough? i cleaned the heatsink well also, and am about to put some arctic silver.
thanks
AG
thanks
AG
