i need to reford myself presenting a speech so that i can listen to it and read it at the same time so i can memorize it quickly. i have a audily 2zs card and a mic. my question is how to i record the sound. thanks for your help
Um... plug mic into mic port on sound card, make sure mic port is not muted, use recording software to record? There's a 'Sound Recorder' program included in Windows (normally under Start Menu/Accessories) that you can use if you just need to record some basic audio.
Hi, Sound Recorder was only capable (on purpose - MS) of 30 seconds of sound. You could cheat it by adding several Wave files together, but not worth the trouble. Windoze also has Windows Media Player. It has no such restriction. Luck, Jim
