Hi
For a new build with m-atx motherboards and choosing between MSI B450M GAMING PLUS and ASRock B450M Pro4 (mainly those two).
It's a drawback for the MSI board that it only has two ram slots.
At least that is what I think. Because when I look up in the manual for the ASrock B450M Pro4 it has the below table for Ram. And in that table, only low speeds (<2400) are supported when using 4 Ram sticks.
- Does this in fact mean, that in practice you cannot use 4 ram modules in an ASRock B450 Pro4?
As it will go to 2400mhz.
I'm planning on buying minimum 3000mhz Ram, and a Ryzen 5 2600 processor. I do not plan to overclock specifically, but isn't it so, that the MB and processer by itself scale frequency up in "burst" when needed, so 3000 ram is a good choice over 2666 ram?
Or is 2666 ram with a Ryzen 5 2600 - not overclocked - just as fine, as speed will never exceed 2666?
From AS Rock B450M Pro4 manual page 22 - link
UDIMM Memory Slot Frequency
A1 A2 B1 B2 (Mhz)
- SR - - 2667
- DR - - 2667
- SR - SR 2667
- DR - DR 2400-2667
SR SR SR SR 2133-2400
SR/DR DR SR/DR DR 1866-2133
A1 A2 B1 B2 (Mhz)
- SR - - 2667
- DR - - 2667
- SR - SR 2667
- DR - DR 2400-2667
