Hi All,
I just received a CD which is supposed to contain a program to install.
It should have Directories and Sub Directories with auto run in the initial directory. However, with Explorer, it only shows one hugh File and is listed as a East Cd Creator Image File.
Is there a way to get this Cd to work and show up as a bunch of files to be installed? When it is inserted in the Cd reader, it doesn't do a autorun which it is supposed to do.
Thanks for your help.
Len
Len
