Question How to re-enable WiFi that was disabled through a physical key
manasan
  • I have a F8 key in my keyboard and I disabled my WiFi using it and now that key is broken and not working SO is there any way to enable WiFi that was disabled using that F8 key back using any software hack?
thetechfreak
75
9
Just open your settings app in Windows and go to the WiFi option. In most cases the hardware button just turns it "Off" in windows. You can easily enable it again from the app
manasan
No Luck and I think those are are two different things,controlling WiFi in settings is different from controlling WiFi through a key in keyboard
sdifox
101,008
18,130
Go to device manager, network adapters, right click on your wifi adapter and enable.
You can also enable on screen keyboard and send fn-f8
