Originally posted by: cnhoff
I have a DivX4 avi and the mp3 file containing the sound, but because of my disc running full, GordianKnot did not put those two together in one file.
How do i do this using NanDub?
Nandub makes this process much easier and can handle any kind of MP3 file, not only CBR so it's the suggested program for this, not Virtualdub.
Start up Nandub and load your video (Control-O). Then set video to direct stream copy (Video - Direct Stream Copy).
Now you have to load the MP3 file. To so so simply select (VBR) MP3 audio from the audio menu which brings up a selection window where you can select the MP3 file.
If you have written down an audio delay in the process select the Interleaving option from the above menu:
Enter the delay value from your AC3 file in the Delay audio track by XY ms field. Negative values get a minus in front of course. Then press OK. There's no need to change the other values.
Make sure audio is also set to Direct Stream Copy, then press F7 and save the AVI under another name then the file you loaded at the beginning. If the audio is asynch after joining read how to make it synch.
Copied verbatium from doom9.org
