use the lever on top, that'll loosen the stranglehold enough that one side will be loose, then pull on the one side to move it away from where it clamps down (gently), then on the other side pull the plastic clamp part away, you should be able to lift it up.
but from the picture you included, it looks to be already removed. 😉
