If you are using Adobe to view the PDF, when you select "Print" and the "print" page comes up -
Locate "Pages to Print", at the bottom of that is "more Options", select that.
Tick the "Current View" box and whatever is visible in Adobe at the magnification you have selected in Adobe will print.
It will also be showing in the picture of the page that is visible there.
Note that that is for that single page only.
Is that what you were looking for?
