I've turned off all fans and still have dust on almost every part of the case I'm painting... I ran some steel wool over the surface between coats and it took off most of ths tuff, but left some thin pieces of wire from the wool.
Any good way to protect the surface from dust other than a clean room?
Also, I'm using regular krylon and it's taking hella long to dry? How long does this stuff take to not to tacky?
