crimsonjax
I was wanting to measure how much wattage my system currently pulls under full load. How and what do I need to do this? I have a multimeter but not sure how to use it too measure this. Thanks.
You need to use a power meter (also called a Wattmeter). Simple plug in ones are easily available for a few $.
Cheap DMMs won't measure AC current, and I wouldn't recommend using a DMM for measuring AC current because of the danger of splicing into mains wiring (unless the DMM has a current clamp).
Just one thing to bear in mind is that if you just measure the current with a clamp-meter, you can't necessarily calculate the total power from that (especially not for comps). If you multiple Amps * Volts (as measured by a DMM), you will get an upper limit for Watts (but the actual Watts may be quite a lot less). See this pic from my home-made power meter for an example of this problem.
