i am using a leadtek geforce2mx, and i overclock the card when i play games. but how do i overclock beyond 220mhz core and 210mhz memory? that's the maximum i can set with the detonator 6.31 driver from nvidia.
oh i mean that in the display settings in the control panel, there is this slide bars for speed adjustment in core and memory, and the max is 220/210. so i couldn't slide the bars any further to the right.
