Can you guys tell me how to do it, preferrably step by step? I wanna just update to an unlocked bios, and then fiddle with frequencies. Also, give some personal insights on the process. Thanks!
Download Omega's unofficial RadEdit 1.1D... then ATIflash... if you have the bios ready then just load it in RadEdit and adjust the frequencies from there. Then make a DOS startup disk from windows... extract all the ATIflash files on that disk... restart and boot off the disk. Type ATIFLASH -P 0 whateverthebiosfilenameis.bin Good luck bro... don't hunt me down if you BIOS flash goes wacko. :Q Perhaps the people at rage3d could help you better if my crude explanation doesn't do it for you.
