How to open case of IBM NetVista "pizza box" case
accguy9009
504
10
I got a few IBM NetVista computers. They are about 8 years old. I need to get inside the case to replace some hard drives, etc.
I can't for the life of me crack the cases!! These are what I call "pizza box" cases, where the monitor sits on top of the computers. They have locks on the units but I have the keys and they are clearly in unlocked position. Hopefully someone here has worked on these before as I know IBM sold a lot of these at one time. Thanks in advance for any help you can offer me.
http://s660.photobucket.com/al...view&current=case3.jpg]
[/URL]
http://s660.photobucket.com/al...view&current=case2.jpg]
[/URL]
http://s660.photobucket.com/al...view&current=case1.jpg]
[/URL]
brblx
5,499
tiny photos are tiny.
looks like the casing comes apart in halves. back screws are out, maybe there are more screws hiding under the front panel.
accguy9009
504
10
there are no buttons on the side of the case. It does look like they come apart in halves. I removed the case screws from the rear but I
think you may be right, more screws must be in the front. I will try that, thx.
Beanie46
527
You have to remove the front bezel first. There you'll find a pair of screws to remove, then slide the top forward and up to remove. To remove the bezel, you have to release a hidden latch just inside the bezel edge along the side that the IBM name is printed on the front of the bezel....opposite front edge from where you see the CD-ROM drive.
A good resource:
http://www-307.ibm.com/pc/support/site.wss/MIGR-51970.html
accguy9009
504
10
problem solved. The front of the cases were tough to open without breaking the clips but once removed, 4 screws later the top half of the cases were able to be removed. thx to all who replied.
Thx, Beanie46
