how to oc with riva tuner
Captante
30,353
10,876
No you arn't... its not that obvious where the setting is, although once you find it you'll have no trouble.
On the tab titled Main, look about 1/4 of the way down on the right side & you should see a small arrow with the word customize next to it, click in that arrow & menu pops up, select the picture of the video card & you should find the oc'ing settings.
Navid
5,053
You need Rivatuner for unlocking 6800. But, for 6800 GT, I don't think there is anything to unlock. Why not use ATITool? It is much simpler to set up.
http://www.techpowerup.com/downloads/341
If you have to use RivaTuner (why?), you can, and I am sure you will get links here.
