How to mount string lights and trellis across patio (stucco on one side and brick on the other)
alfa147x
29,307
Hi all - We've got a patio with a stucco wall on one side and a brick wall on the other. I want to zig-zag steel wire to drape string lights across them. I'd also like to mount a trellis for my jasmine and bougainvillea to creep across. My initial plan is to mount pressure-treated and stained/painted 2x4s across the walls giving me something to attach to for the lights and trellis without having to repeatedly drill into the brick and stucco.
Nov 17, 2019
13,255
7,856
I'd look at something vertical from the ground up. Then add cross ties. All the support for weight is carried by the verticals and you'd only need one anchor at the top of each to prevent leaning out from the wall. Goop the snot out of the top of each to let water run off, instead of behind.
Might even look at something galvanized like a fence post top rail, or maybe electrical superstrut. No chance of wood rot or wood insects and may not cost all that much more due to the lack of ongoing maintenance.
