How to mount plate on front of Camry?
ManSnake
4,749
Ok, I have been wondering how do you mount a license plate on the front of a new Camry? I don't think there are holes on the bumper for you do do that, are there?
NutBucket
27,119
613
Uh, there should be. My cousin bought a XLE V6 last month and his has a dealer plate bolted to the front.
NutBucket
27,119
613
Btw, my parents have an 01 and from the looks of it the plate is just screwed into the plastic front bumper cover.
ultimatebob
25,134
2,450
There should be some punch-out holes on the front bumper, where you would install the front license bracket. If you can't find them, ask your dealer to install the license plate bracket.
