How to mount floppy in Antec SX830 case, and LED's won't light
joshdoe
500
I just pulled a floppy drive from an old computer lying around to install in a SX830 case. I don't see how in the world I'm supposed to do this. I figured out installing 5 1/4" drives with the rails, but I can't see how to install a 3 1/2". Anyone know how to do this?
I've got an Abit KT7, and after hooking up the LED's, they won't light. Both the HDD and the power LED's won't light up at all, during start-up, use, or shut-down. The speaker, power and reset buttons all work fine. What's wrong?
Thanks
joshdoe
500
I guess I can try that, even though they are plugged in the way the manual described, with pin 1 in the right place.
ride525
1,379
Do you have the LED connectors hooked up correctly? My Antec 282 case and KT7 are hooked up with the writing on the connector facing the front of the case.
joshdoe
500
Next time I power off I'll try switching them. All connectors, PW sw, RST sw, PW ind, HDD ind, are plugged in the same way; the writing is facing in to the mobo, with pin 1 on the right looking down. Pin 1 is indicated by a small arrow on the plug, I believe.
ride525
1,379
Well, either the KT7 manual or my case manual (I think KT7) said to have the writing on the LEDs facing out on the motherboard.....towards the front of the case...
