Hi,
I intend to get a Sapphire 9600 XT Ultimate, which is very silent cause it doesn't have a fan. Normally a fan isn't needed with this one, but just to make sure, is there a way for me to monitor the temperature, like to see if doesn't go up to high when heavy gaming or something? Can an Asus P4C800 motherboard report this or does this only work if you have an Asus videocard? By the way, what is the max. allowed temp for a videocard to run safely.
PS: does the passive cooler of the Sapphire 9600 XT Ultimate allow you to install that optional Zalman fan if you want or isn't that possible with this card? I believe it needs to have holes somewhere so you can install that optional Zalman fan.
