How to measure throughput and range?
BMW330ci
Hi guys-
I'm hoping a network guru can help me out here. I want to test my router's range and throughput but how do I go about doing that? What sort of software would I need to run on my laptop?
Thanks for your help!!!
Routers don't really have a range. I'm guessing you have a wireless router, in essence a router with integrated Access Point. The AP will have a range. For accurate signal strength and quality I'd recommend netstumbler, assuming your client card is supported and most are nowadays. For throughput I prefer FTP, however you could also setup a webserver and download files from the client that way. That's a couple of basically free methods that should give you an accurate reading.
Originally posted by: BMW330ci
I read in PC Mag that they use Net IQ's Chariot -- is this reliable?
The Utility in the link of my above post is a Free subset of Chariot.
:sun:
