How to measure mAh capacity of a rechargeable battery?
No you cant really measure it with a tool. You'd need it to be printed right on the battery or go look it up with the manufacturer. As far as lying about their product, its hard to prove.
I would ask on Amazon if people are happy with them and are they getting their money's worth.
thx.
they have 4 1/2 stars but only 300 ratings.
LOL at $7 for a "smart" charger AND 8 batteries. Those cells are undoubtedly junk, and it's unlikely the charger is anything special either.
Here's a thread on chargers with some good answers:
A quality charger will know when to terminate (and display metrics), and that gives you a good idea of the capacity of a cell.
The NiMH cells to get are Laddas sold at IKEA, which are rebadged Panasonics.
thx.
If it's Amazon, it's probably safe to assume that half of those "5 star" reviews were bought and paid for with amazon gift cards and/or free product in exchange for the positive review.
Out of the remaining, you probably have some people who did "early" positive reviews before they had to chance to start experiencing problems. You'll find that problem anywhere, though.
Yup, $7 bucks is way too cheap for any of it to be good quality.
Pretty sure you can easily determine with a load, a multimeter with current sensing, and a stopwatch. Best thing to do is get a load that is a nice even number (like 1A or 500mA) and then just see how long it takes to go from full capacity to discharged.
An electronic load that can keep a constant current would prolly be best, with a resistive load the current is going to change as the voltage drops while the battery discharges. Think most batteries though the voltage doesn't drop too much until it is basically dead so you could prolly still get a good idea of the capacity with a resistive load.
