how to map a network drive in dos?
DAM
6,102
Help please, I know this is not the right forum, but I need to get this answer quick, I have been searching for this for about 45 minutes with nothing.
I know you have to use the net use command comething like this:
c:>net use J:\\server\directory password [/yes]
but it doesnt work, anyone know the exact syntax? thanks!
dam()
konichiwa
I don't have any idea, but usually if you type the command followed by a slash and then ? it will tell you the syntax:
net /?
DAM
6,102
yeah i did that koni, but the it gives me really crappy example in dos :---(
dam(me)
Entity
10,090
net use drive: \\server\sharename /user:Domain\username <enter>
then password
now would someone tell me how to unhide a partition in 2k?
rob
DAM
6,102
thanks entity, i figured it out right before i looked at this thread. if your admin you should be able to see all partitions. thats my guess
dam()
Entity
10,090
Yeah, but you can't boot off of a hidden partition. I'll just boot to a different HD and unhide it (damned disk-disk copy messed it up).
Rob
Entity
10,090
Yeah geno, but I didn't want to post anything that could give anybody else ideas...<cough>filter</cough> if you know what I mean.
Rob
DAM
6,102
entity go to your administrative tools, open the disk managing tab.
dam()
geno
25,074
4
<< Yeah geno, but I didn't want to post anything that could give anybody else ideas...<cough>filter</cough> if you know what I mean >>
Good idea :)
Entity
10,090
anyone know if powerquest creates a new unique system ID when copying one drive to the other?
Rob
DAM
6,102
entity: you got me on that one dude, i have no idea.
dam(0)
