Hi - I have a LAN (192.168.10.XX) behind a Linksys router running Tomato firmware. I use an old Tranzeo transparent WIFI bridge to connect to my ISP:
To configure and manage the Tranzeo bridge I've been connecting my PC to the Tranzeo's ethernet port (first giving my PC a fixed IP address in the 192.168.10.xx range). That works but it's a hassle.
Is there any way I can access the interface of the Tranzeo bridge from the LAN or WAN sides? I don't mind changing the Tranzeo IP to a different domain and doing some static routes in the Tomato router, but I don't know how that would work. Also, the Tomato runs a PPTP VPN server so I can connect to the LAN from the outside, so from the WAN I could access the bridge even if it only has LAN-side access. It's just a hassle to fiddle with cables to access the bridge interface, which is located on the WAN side of the router (and which can't be assigned a static or dynamic IP address from the ISP).
Advice? Thanks...
Advice? Thanks...
