how to make system files non-system
bigalt
1,525
I'm trying to recover from the w32/klez.e@mm virus which renamed a bunch of exe's and made them system, read-only, hidden, etc.
I can take off all of those flags except for system. Anyone know how to do that?
db
10,575
292
hmm, been awhile.
might have to go in dos and remove all attributes first, then make r+ h+ s+
bigalt
1,525
they are currently system files. I would like to make them normal files.
how do you remove attributes in dos?
FatMan42
219
bigalt - you need the attrib command. It's used like this...
Displays or changes file attributes.
ATTRIB [+R | -R] [+A | -A ] [+S | -S] [+H | -H] [drive:][path][filename]
[/S [/D]]
+ Sets an attribute.
- Clears an attribute.
R Read-only file attribute.
A Archive file attribute.
S System file attribute.
H Hidden file attribute.
Specifies a file or files for attrib to process.
/S Processes matching files in the current folder
and all subfolders.
/D Processes folders as well.
...so, if you want to make virus.exe in c:\stuff directory non-system, you'd do the following. C:\stuff>attrib -S virus.exe. The /s switch allows you to catch the contents all subfolders and /d operates on the folders themselves.
