- Dec 27, 2005
- 1,141
- 35
- 91
I bought an Antec NSK4400 and the temps on the drives are running a bit warm. The 80mm fan mount doesn't go in front of the drives, and I can't install a fan between the metal and plastic bezel. I was thinking of putting a 120mm fan on the floor of the case using velcro, but I need to raise it up a bit. What can I use to add height but keep it stable while running?
