Originally posted by: JackMDS
Originally posted by: JRock
Originally posted by: Slowlearner
Buy one for <$10, and save yourself a whole lot of pain
Why when it should only take like 2 mins... 3 tops...
Because statistics show that when the inexperienced crimps there is mot then 50% probabilities that the cable would not work or would be "Quirky.?
When you need the skill for a real Job you have no choices, you crimp, you crimp, and you crimp, in the process you use professional Cable tester until you get it right (and for some people it can take many many cables until they get it right).
If you need few cables, you would not buy a Good tester. You would save few $$ on the cables, and probably will spend more then few hours scratching you head why the Network does Not work or it works slowly.
:sun:
