davidgolani11
I have a flicker problem, apparently a common one. When my HD6670 video card switches between 100Mhz and 800Mhz I get a full screen flicker, it happens very often and is extremely annoying. It has happened since I installed it and no driver update to far has fixed it.
I've tried MSI Afterburner, set 2 profiles to 800Mhz but it still clocks down to lower speed / low power mode.
Sapphire is of course no help, and no amount of driver tweaking fixes it. I tried the HDMI output, the DVI output, both have the flicker.
So is there a way to lock the clock at maximum? Can the firmware be patched?
Thanks
Thanks
