How to locate IBM Remote Supervisor Adapter IP?
gar598
1,915
Not sure if this qualifies as highly technical...Trying to locate the IP IBM Remote Supervisor Adapter (similar to HP's ILO or Dell's DRAC). Generally, it's stored some place on the system (the ip config) - any ideas? I've looked through the manual with little luck (http://www.mta.ca/torch/pdf/ex...dapter+user+guide.pdf)
Thanks in advance.
Moved to appropriate forum - Moderator Rubycon
