Originally posted by: leconc
Made major progress today. Got crossover cable, got ICS set and can connect to internet with both computers. Now what I need is:
1) The best way to get the dialup connection for F@H set right. On pc#2, what should be set in tools, internet connections, area. Nothing is there now.
If IE works from the second computer, I would set F@H to use the same settings as IE (in other words, the default ones) via the advanced preferences of F@H config.
2) How do I purge a old wu?
Before doing any of this, make sure your F@H client is shut down. Now, to attempt to resend stuck WUs, run the F@H CLI with the "-send all" flag (don't try too often, like more than a few times per day, because if the server the WU came from is down, you'll only make the problem worse). If there's a genuinely stuck WU, then use the "-queueinfo" flag to find out what number it is, and then use the "-delete ?" flag, where ? is the WU number, to remove it.
3) Since this is a shared dialup line with my phone, how do I keep both computers from dialing while I'm on the phone? They can download and send stuff while I'm online, I don't care about that.
There ought to be an item somewhere in the properties for your dialup connection (I think it's on the second tab, but I don't have a system with a dialup connection now to check) that says "wait for dial tone" or similar. That works perfectly for most people, but sometimes my computer would still try to dial while I was online. As a precaution, make sure your redial attempt settings aren't insane (perhaps 3 times to try redialing, and give 30 seconds between tries) so if the system doesn't work and wants to dial anyway, you won't be too annoyed.
