How to keep track all my usernames and passwords in all member-registered sites
abdulbadii
31
How to keep track and manage all my usernames and passwords in all member-registered websites by commands script ? (what tool in it, may be wget tool inside it)
DaveSimmons
40,730
670
I use a text file and notepad.exe, but there are many password managers out there and Google Chrome will also remember passwords for you.
you2
6,950
2,012
you could use a simple function f(x,constant)=md5hash(x+"constant") where x is the forum url. When you have to rotate password change "constant" the only negative is updating all your passwords at the same time. Now your password is not actually stored anywhere and you just have to remember one 'key'
13,851
Usernames as is, passwords hashed with a salt. The salt is stored with the hash. It sounds counter intuitive but the idea is that if you get hacked, the hacker need to run the hash function for each one, vs use an existing dictionary. So you don't just hash it directly, you hash it with the salt. The salt is just going to be a randomly generated string that you append to the password. That string is then stored with the account so it can be reused when verifying logins. When the user logs in you then repeat the hash function on what they entered, and then compare it with DB.
