How to increase signal strength on wireless network?
amol
11,680
I have a D-LINK DI-624 router (Xtreme G, but it's on 54Mbps)
I have a DWL-G650 PCI card in the computer
The router is in one room, on the north side, and the room my computer is in is two rooms away, on the north wall
The antenna is facing my computer
However, I usually get signals of "Low" or "Good", but nothing higher
Is there something I can do/buy to increase the signal strength? Possibly an antenna with a wire, so I can place it on my desk instead of connecting the antenna straight into the computer?
TIA :)
JackMDS
29,550
425
