Question How To Increase Laptop Volume Beyond 100% ?
retab12332
77
Is there a way to raise the laptop volume after 100%, I can not hear the other person that clearly during ZOOM? Are there programs for this?
damian101
291
107
You might want to try enabling Loudness Equalization for your device.
It's under "Enhancements" in your audio device properties. I don't remember the best way to get there though, I have no Windows machine around to test.
retab12332
77
There seems to be no improvement.
Motostu
588
617
Is it a problem with 1 person in particular, or any zoom call? If just a certain one, there is an option to increase the microphone gain; you could have the other person give that a try?
retab12332
77
Everything is working normal. It's just that its a large room, and I want everyone to hear it during ZOOM.
Motostu
588
617
Maybe get some external amplified speakers? I don't think laptop speakers are going to do what you want.
AnitaPeterson
6,030
574
What do you recommend for external speakers? Budget choices, if any
Actually, you don't even need speakers.
Unless, of course, you can find some good ones for really cheap.
Any portable speaker/soundbar will do the trick, as long as it has an Aux In.
