How to hook a garden hose up to a fire hydrant
Exterous
20,591
3,807
With enough adapters anything is possible! (also the unofficial Apple motto)
Reactions: paperfist
13,909
Guessing it's a temporary feed while they are repairing water mains. I've seen them do that here. I always wonder how they stop it from freezing, I guess they just tell people to leave the water running.
skyking
22,816
5,977
first thing is a meter, the second doohicky is a double check valve. Gotta have one to prevent siphoning really nasty things back into the water mains.
paperfist
6,539
287
www.the-teh.com
I never understood the check valve idea. With the amount of pressure those put out how in the world would anything back flow?
The don’t freeze because they have a drain valve that open below the frost line when the valve on the hydrant is closed.
local
1,852
517
Easy, water pressure goes away due to a line break or pump failure. Odds are not good but you don't want to be on the receiving end of something toxic in your water if it happens.
Reactions: skyking
KB
5,406
389
Couplers and adapters are truly a godsend. This comes from my own experience.
That adapter contraption thing probably cost 300 bucks in total.
PottedMeat
12,363
475
i wouldn't say 300 from the plumbing tag onwards, maybe $60 and half an hour at home depot mixing and matching fittings and putting the incorrect ones in the wrong boxes
paperfist
6,539
287
www.the-teh.com
I dunno 1.5” copper fittings like make adapters are $15. Black couplings that size are like $10. Stuff is pricey.
mpo
458
51
I have questions...
Seeing as the hydrant is an East Jordan Iron Works model and the tag has a 248 area code...this is somewhere in the Detroit area.
Some municipalities will allow temporary businesses draw water off of metered hydrants. You can see the same setup here: https://goo.gl/maps/PvsLgo9hoQu. There is a temporary garden center that operates every summer. They pull water from the hydrant.
Some types of municipal use of water has to be metered, too.
Reactions: Kaido
13,909
Guessing it's to let people fill their pools? Though I have also seen this as a temp solution when they're doing construction. But if this is detroit my guess is that it's just people stealing water lol. Nobody even police is going to question it and just let them be or risk getting shot at. Somebody else is probably going to come steal that whole contraption anyway to sell it for scrap metal.
34,601
As has already been pointed out, there is a meter present. Therefore odds are most excellent that the setup is legal. Your assessment of Detroit is about as accurate as us'uns describing Canadians as moose piss swilling penguin fuckers.
sswingle
7,183
45
They use this around here for street fairs. All the food vendors need a water hookup so they put a meter on the hydrant and there you go.
paperfist
6,539
287
www.the-teh.com
Winner!
I emailed the company on the tag and they said:
"It’s original use was I think for the state fair to supply water to multiple food vender trailer"
