How to hide/mask user input in C++ console applications
CaptainKahuna
2,228
www.billda.com
My program has a password field, and I need to know how to hide or mask the users password as he types it in. I would be fine with using "*"s, or simply not displaying anything as he types. Thanks.
HJB417
763
I think you might need to use conio.h, I've never used the library before but quickly looking at the functions names, I think getch might do the job. getch gets a character from console but does not echo to the screen
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Correct!!
HJB417
763
have it loop getch until it recieves 13 which is what pressing "Enter" returns. And whenever it doesn't return a 13, output a * or something, if you want, to show that the user it entering the password.
EagleKeeper
Staff member
Oct 30, 2000
42,589
well, the ASCII code returned when you press "Enter" is 13
0x0D
Depends on how many fingers you use to couint with
thatbox
253
Youd have to use character arrays and a do...while (to make it stop once enter is, er, entered) with getch(). And although I don't know much about it, theres also a getchar() that uses a different library file, but I dont remember it. How can you not love working with character arrays!?
