How to get VNC to auto-load
Dyngoe
373
Hi Y'all,
I have successfullt installed VNC on three of my comps, but the fourth is wierd. Everytime it(the fourth comp) boots, the vnc window appears and not the task bar icon. I installed it exactly like all the other comps, but it doesn't want to work for me. Any suggestions?
As Always,
D
Ladi
2,084
OS? Did you install VNC as a service? Or do you just have it running from the Startup program group?
~Ladi
Cyph3r
790
What Ladi said..you can do "vns -install" to make it a service if it isn't and you should be set..Regards
