Doesn't a stiffer rear help reduce understeer, which is probably an issue for the tC?
Yep, you'll get more weight transfer in the rear which will reduce the rear's grip faster than the front's. Similar to the way a sway-bar works.
yeah man, BMW didn't just have one guy surf online and buy bunch of OEM parts to put together 335i. It's years of experience from past BMW's, hundreds of engineers designing, testing, redesigning and retesting to get a balanced overall design with good handling, power and comfort.
Wanna have driving experience of a 335i? Just go buy it already.
<--- Proud owner of 335i![]()
Bring it.
:awe:
But yeah..OP, IMHO you're best off to save for another car. He probably has a quicker steering rack too, which has a huge impact on the steering feel you're referring to. That won't be fixed with new suspension - and speaking of suspension..., coilovers typically ride pretty rough. Great performance when set up properly, but your ride will suffer. There's no way I'd run coilovers on a DD.
Start with sways and see if that helps - then start saving for a 3 series.![]()
I just noticed this:
Rear springs are stiffer than the front?
That's 448lb/in and 560lb/in - for reference, Tein HT coilovers for a Mk2 MR2 are 224/504 respectively. Your car is about 100lb heavier than mine...I'm going to guess that those coilovers at that spring rate are going to ride like shit.
1) Run 'em till they need a rebuild.
2) That'll likely depend on the quality of the coilover- I've never looked into them, so I don't know how long they'll last. Once they're worn out, you can typically send them to the manufacturer for a rebuild (not sure if there's a DIY solution available or not).
3) No.
4) !!!
5) Absolutely.
pass on the coil overs they will ride like crap and be dead in a year your best bet to improve handling without suffering ride quality. is by going with a quality lowering spring. i use eibach on most everything i drive or any cars i happen to work on *coughjleecough* for your car i would honestly go with the eibach pro plus kit. its a set of eibach pro kit lowering springs 1.2" drop and a pair of there front and rear sway bars. this will give you a great improvement in handling over stock but not suffer on ride quailty and dont have to worry about them having to be rebuilt in a year cause they were cheap china crap! not to mention at $460 from tire rack it will save you money! and even with install and alignment youll still be undercost of just buying the coilovers.
To get better handling out of your tC you have many options. It will not turn it into a BMW 3xx because of the many reasons already mentioned, but you can certainly make it more fun to drive.
To preserve much of the stock ride quality I would keep the stock springs and not lower the car any. I would buy Koni 'yellow' Sport shocks for all four corners, on 'soft' they should be pleasant, but will get very aggressive and fun when you dial them up (free lifetime rebuilds too). Then I would get something like Hotchkis front and rear sway bars, should be stiffer than stock, and are adjustable so you can change them to balance the car the way you like. Then I would get the lightest set of wheels with the best set of 'extreme performance summer' tires I could justify buying. Dunlop Z1 Starspecs on a Kazera KZ series wheel would be a great setup.
To pick a priority:
-sway bars
-shocks
-wheels/tires
^This.
The original poster specifically mentions "roll".
Stiffer sway bars in front and back will make the biggest improvement in the "feel" he is looking for without compromising ride quality or wasting money. They are a very cheap and easy mod.
Assuming his stock shocks/struts are in good condition, I would look for a good set of performance tires next.
After that I would learn to drive the car to the absolute limits of the stock suspension before spending any more money on modifications.
I'm confused, I thought shocks were the springs? What's the point of replacing the shocks but not changing springs? Sorry, I'm pretty new at this.
I watched some youtube videos of some before/after comparisons with front + rear swaybars and honestly it barely made an impact at all it looked like-- the side opposite the turn was still dipping way low and the chassis rolling....?
edit: found it: http://www.youtube.com/watch?v=ltiwTj7cbAs
Oh, right...derp. I saw rear spring rates stiffer than my MR2 (which has an engine on top of them) and went WTF.
Stock Scion tC spring rates are 146 / 268. Going to 448 / 560 is going to be like driving on bricks.
I would highly recommend a Koni Yellow / Eibach Pro-Kit combination. I am confident it will provide a far superior ride, and for what you're looking for, you really don't need coilovers.
$489.94 for Konis and $202 for Eibach Pro-Kit springs (or $460 for springs and sways. You'll be much happier with that than with coilovers.
Coilovers usually need attention paid to the locknuts time to time. Depends on brand...almost all will be sealed units so no oil maintenance.few other questions:
1. What's the maintenance on coilovers? Change oil like in bike's suspension?
2. How long will they last? Do they need replacement, or would I just replace the springs?
3. Will lowering my car 1" make me more likely to get pulled over?
4. ???
You can setup a car to be perfectly flat, but if the tires lift/unload because there is no roll (or not enough) then you end up with worse handling/control than you started with.
Being perfectly flat in a turn is not the goal. Maximum grip and smooth/controlled transitions as weight shifts is what you are looking for.
lifting a tire isn't bad on many cars.
Lifting a tire is always bad. It means you have 100% weight transfer and are getting less-than-optimal grip on that axle. Some cars can handle it just fine structurally, but it is very bad from a performance standpoint.
You have no idea what you are talking about. The outside rear tire on many cars is nearly unloaded anyway in hard turns.
I'd read a basic suspension book, Fred Puhn's is dated but accurate and cheap.
http://www.youtube.com/watch?v=cPNwmoFAap8
Stig Focus RS lap, note the inside back tire is off the ground quite a lot. What's up with that?![]()
Design flaw, or just what happens with that setup when driven 10/10ths a la Stigness? The lap time was quite decent.
