Originally posted by: tk109
Well you can get Windows Vista if you dont already have it. They fixed all that was wrong with the audio paths in XP. Made more than a huge difference for my x-fi elite pro. I can't believe the sound I'm getting out of it.
Anyway for now and something that is free you can get foobar2000 and use asio drivers. (or kernel streamer). That way it bypasses most of the problems in xp. (Vista still sounds a lot better than that though)
If you are already on Vista then ignore all this.
