- Dec 21, 2000
- 5,280
- 0
- 71
Hey guys! I'm pretty torked here. I have a Motorola Digital Cable receiver and I am getting a lot of background noise. When using the stereo RCA jacks on the back to hook up to my computer/speakers for sound, I get a loud HMMMMM sound and it ruins the quality of my captures. Also, there is noticeable amounts of flickering white lines...sometimes scroll up the viewing screen on my computer.
I'm using a S-Video connection between the Digital Cable receiver and my ATi AIW R9700 Pro. The sound is hooked up via dual RCA stereo from the Cable receiver to a 1/8" mini-stereo plug that goes into my Audigy 2.
I've double-checked my cables and they're good and no hissing when used with other equipment. I can unplug the coax cable from the Digital Cable receiver box and all the HMMM sound goes away! I bought an inline 75 ohm DC block to see if that would help cut the noise, but no avail.
Click here to listen to the background noise that is present when I have the cable box off or on.
Oh, one more thing, I plugged stereo RCA cords into the line inputs of the motorola box and set them on the back of my computer to ground the cable box. The noise then goes away as long as the cable box is off, but once you turn it back on, the noise comes right back.
Help!
Help!
