how to get a really small phillip's head screw out
OVerLoRDI
5,490
4
I'm replacing the hard drive on my mp3 player and there is just one very small phillip's head screw which I cannot remove. It is very shallow and the only driver that won't slip out immediately is a glasses screw driver, which obviously I cannot grip well enough to turn. Anyone have any tips? I am tempted to just cut the plastic around the screw and completely get passed it that way.
Leros
21,867
7
Try gripping the screwdriver with pliers. Or buy a set of small tipped screwdrivers.
Lash444
1,708
64
Drill a hole in the eyeglass screw driver, then put something inside of the hole to give you T shape that makes getting torque easier?
SonnyDaze
6,867
Try wrapping tape around the handle of the screwdriver making it a little larger...it maybe easier to grip.
herbiehancock
789
Jeweler's screwdrivers. Ever notice how they have a rotating top cap on the screwdriver that seems so inconvenient and silly? They're there so you can put downward pressure on the screwdriver with one hand and still easily rotate the shaft and blade with the other hand. Been able to loosen many a stubborn screw with them when all other types of miniature drivers have failed.
scott916
2,906
If it's a Nomad Jukebox Zen NX, I feel your pain. LMK if you get them off, I want to know what screwdriver set you used; mine is crap so far.
AtlantaBob
1,034
Originally posted by: hypn0tik
Use a really small screw driver.
Not to sound like a smartass, but, this isn't a bad idea. I had the same problem trying to open the memory cover of a Dell 700M. Almost stripped the screws out. Then I went to MicroCenter, bought a $5 screwdriver set, and have been able to take out miniature screws ever since. Good luck!
Mrvile
14,066
Um, the OP is using a glasses screwdriver, which is pretty small already...
