My limited 11ac experience, 11ac is still pretty decent. It is very heavily dependent on a good client and a good base station and also drops with range pretty significantly, but same room, I've seen TP-Link Archer C7 and Intel 7260AC cards push in to the 400+Mbps range, which is the better part of half of the 867Mbps singaling rate of 2:2 11ac 80MHz. Move a couple of rooms over and it does drop fast, but its still over 200Mbps.
Just as a real world example of this.
I had a pair of TP-Link Archer C7s with one in bridge mode so that I could connect my upstairs and downstairs without a cable. They were through a floor and a wall and about 10-12 feet apart in a straight line about 45 degrees. When I first tested the LAN speed I was getting about 212Mbps. When I moved it 2 feet to the left so that it wasn't directly below the metal ducting from the furnace, speeds jumped to about 360Write/425Read.
5GHz is so picky......
