How to fix this IE problem in W2K PRO....help!
dayg
Hi,
I have a machine that gives me this error message everytime after closing a particular site/page. Error reads "an error has occurred and microsoft Internet Explorer needs to close" This is very annoying because it closes all my IE windows.
How do I fix this issue. Links anyone? I know in the past, in NT 4.0, you could go into add/remove programs, and click on IE, there you could either add a component or restore IE.
Is there a way to do that in W2K? Thanks.
ditto! I would upgrade to IE6 or reinstall 6 if you already have it. Sounds like you may have a corrupt file or something that flakes out when called upon by IE.
