Hey guys. I have a Gateway MP6954 laptop. It's been a great laptop until recently.
When I plug the connector into the laptop, I have to wiggle, jiggle, and do whatever needs to be done so the laptop stays hooked up to power. If I do not, the laptop doesn't maintain a solid connection and starts eating up the battery power.
When I plug the connector into the laptop I can feel that the little grasper things that hold the plug tightly in place are now loose, or looser. I have to pull the plug almost 90% out until the end of the plug (which is slightly larger then the rest of the plug) connects with the end of the grasper thing to form a tight solid connection...
What are my options? I'm capable of opening the laptop up, soldering on the mobo, etc... Just need to find out what the exact cause can be before I go on a goose chase. I've already tried 2 different power packs (a factory Gateway FOR this laptop, a Targus (with swappable tips), and a cheap-o eBay power pack.
It's obviously not the power packs.
Would love to hear how you guys fix a problem like this! I'm in no place to buy another laptop right now, nor do I have the $$$ to pay someone to fix it.
Thanks all!
Thanks all!
