How To
How To Fix iTunes Error 1667
You may face many issues that may occur using iTunes like restoring the device or updating iOS. One of the errors you may face while using iTunes is ‘Error 1667’. Several times you may face this error when iTunes might not be correctly installed, or iTunes software installation may be incomplete, or any files might be deleted by another program. There are several ways to resolve the 1667 error - use Tenorshare TunesCare Application, Use another Cable or System, Update iTunes, Re-install iTunes, Reset Network Settings in your device. Here’s how to resolve this error.
Use ‘Tenorshare TunesCare’ Application
Step 1
‘Download’ and ‘Install’
'Download'
and 'Install' the ‘Tenorshare TunesCare’ application and launch it on your computer.
Step 2
Fix All iTunes Issues
Click ‘Fix All iTunes Issues’ from the ‘Home Screen’. You’ll notice that the software will scan for the problems and display the result of the scan.
Step 3
‘Repair iTunes’
Click ‘Repair iTunes’. The ‘Tunescare’ will repair the iTunes application, and it may take several minutes for concluding the entire process.
Use ‘Another Cable’ or ‘System’
Sometimes you might face an issue due to connectivity issues or operating system issues. It is recommended to change the physical cable that is used to connect your iPhone with the computer. If this doesn’t work for you, try switching to another computer.
‘Update iTunes’ on your Computer
Step 1
‘Update iTunes’ on Mac OS
If an iTunes update is available for the Mac, users can update their iTunes from the App Store. iTunes will update and install automatically.
Step 2
‘Update iTunes’ on Windows OS
Windows users can simply select ‘Check for Updates’ from the ‘Help’ menu of the iTunes. The iTunes will download and install accordingly.
Step 1
Navigate to 'Reset Screen'
From the iOS device, simply tap ‘Settings’ and navigate to ‘General > Reset’
Step2
Tap ‘Reset’ and then confirm by tapping on ‘Reset Network Settings’. Next, enter your password to authenticate the procedure of resetting the network settings.
Here you go! You just successfully recovered your iTunes from the Error 1667.
Status
Not open for further replies.
Status
