Is your iPhone freezing while charging? This is a recurring technical error many Apple users are facing. There can be many reasons to it – overcharging battery, too many background apps, and, even, faulty phone charger. The foremost solution to this is to restart your phone and check for any problem with the charger. If that is not the case, then you have to restore your phone in recovery mode using iTunes. Let’s have a look at how you can fix iPhone freeze when charging.
Step 1
Connect iPhone to PC
Use USB to connect your iPhone to the laptop/PC. Presently, the ‘iTunes’ logo will pop up on the laptop/PC screen.
Step 2
Put the Phone into ‘Recovery Mode’
Now, put the phone into ‘Recovery Mode’ by holding down the ‘Sleep/Wake’ button and the ‘Volume-Down’ button till the Apple logo appears on the screen. Subsequently, the Apple logo gives away to iTunes icon on your iPhone screen.
Step 3
Open ‘iTunes’ and Select ‘Restore iPhone’
Now, select ‘iTunes’ on your laptop. Thereafter, click ‘Restore iPhone’ to restore your phone in the ‘Recovery’ mode.
In this way, you can fix iPhone freeze when charging.
