How to fix a tire on a hand-truck
Drakkon
8,401
I got a pretty good hand-truck but somewhow the tire popped off from the wheel and now its flat. There is no inner-tube on the tire so i can't figure out how in the world this thing stays inflated or how to reinflate it. Any ideas out there?
amdskip
22,530
13
So it's tubeless? It probably needs to be glued up to the rim to inflate, take it to a tire shop.
Crucial
5,026
Put air chuck on and blow air into it? You should be able to flex the tire enough to get it to seat. We used to use ether(starting fluid) on the semi truck tires to get them to seat. That was awesome.
Cheesemoo
1,653
20
for some reason i hate when people call them hand trucks.....
Its a dolly.....
Stifko
4,799
I would get an inner tube for it and fill it normally.
You can find them at a good flat fix place. I get them for my wheelbarrel and hand trucks.
axelfox
6,719
Its a dolly.....
How do you know which one he is talking about?
andylawcc
18,183
we had the same problem; we have a electric tire pump but it didn't work since the air pumped in came out faster through the gap.
anyway, I brought it to American Tire (aka Discount Tires) and they took care of it.
Tifababy
654
I had the same problem with my snowblower and it just happened to go flat during a snow storm where we got over a foot of snow. I was able to get it pumped up by wrapping a ratchet tie down like one of these around the tire and pumping with a small hand pump. It took a while and was rather frustrating, but safer than lighting it on fire.
Although if you can take it to a tire shop that's probably the easiest. I couldn't get out of my garage because of the snow, so I had to make due with what I had.
I also read online that some people used belts or extension cords to wrap around the tires.
Lounatik
1,845
Small set of hand trucks.... get a piece of rope and tie it around the circumference of the tire and then fill it up. I do this all the time when mine go flat.
Peace
Lounatik
Snuffaluffaguss
973
I put strap around the tire, spray a little lube along the inner wall of the rim, tighten the strap, so that the pressure pushes the tires wall out toward the rim, and inflate with a hand pump. google is your friend, and has many sites on how to do this...
Toastedlightly
7,213
Peace
Lounatik
For added squeeze, twist a screwdriver around that rope to force the bead to seal. This is how I fix my lawn tractor tires.
Gillbot
28,830
17
Peace
Lounatik
+1
Just be sure to get the rope in the center of the tread, that will help force the sidewalls onto the rim then you can fill it up normally. You may need to shift the tire slightly to get a good seal also.
