Originally posted by: Ornery
Spackel is perfect. Might take a two or three applications to fill the hole, but it will eventually. Use a putty knife to scrape the excess off while it's "wet", or you'll be sanding your ass off. Spackle is much less sandable than drywall compound. Sand it flat after each application. You will have to paint it of course.
So regular spackel would work in this scenario? Or would I need a special "wood spackel" like somebody suggested?
