How To
How To Fix 3D Issues In iOS 12
The 3D touch in iPhones senses how deeply users click the icons. Recently, there have been recurring complains that the 3D touch is not functioning properly after they have updated the phone to the latest iOS 12. One of the many and foremost solutions to this is to restart your phone. However, if the issue still prevails, then there are other fixes as well. So, let’s have a look at how to fix 3D issues in iOS 12.
Method 1: Adjust 3D Touch Sensitivity to Light
Step 1
Click ‘Settings’
Select ‘Settings’ from the menu. It will open up a window with all the advanced and general settings controls in your device.
Step 2
Click ‘General’
Browse through the ‘Settings’ options and click on ‘General’. It will enable you to access all the controls for modifying the 'General Settings'.
Step 3
Click ‘Accessibility’
Look for ‘Accessibility’ under ‘General’, and select it. It will open up the next set of control settings in your phone that allow you to access certain applications.
Step 4
Select ‘3D Touch
Click ‘3D Touch’ from the ‘Accessibility’ panel. It will open up the panel of settings associated with ‘3D Touch’.
Step 5
Select ‘3D Touch
Ensure that the ‘3D Touch’ in your phone is enabled. Then you can shift the white circle to ‘Light’. Consequently, your ‘3D Touch’ will start functioning.
Method 2: Enable Assistive Touch
Step 1
Click ‘General’
You have to access all the general settings of the phone to enable assistive touch. Click on ‘General’ from ‘Settings’ menu.
Step 2
Select ‘Accessibility’ from the ‘General’ settings. It will open up the list of controls you need to enhance or modify the accessibility of applications in your phone.
Step 3
Click ‘Assistive Touch’
Browse through ‘Accessibility’ and select ‘Assistive Touch’. It has a wide range of excellent accessibility tools that enables you to pinch, multi-finger swipe, and use 3D touch.
Step 4
Enable ‘Assistive Touch’
Hit the enable button against ‘Assistive Touch’. It will turn green, indicating that assistive touch is activated in your phone.
In this way, you can fix the 3D touch in iOS 12.
Status
Not open for further replies.
Status
